Hi! I have a problem with 3d parts in the Detail Center preview. Some parts are not visible on the cell, but some parts are visible in 3d as in the model. How to make all the parts 2d?
Hello Данил Куликов,
Thanks for posting this query in Bentley Community Forum.
There are many possible reasons like
- In detail style you have created Object Group under Views tab and those which are not coming in preview, might be they are not called as seperate groups.
- Check if you have assigned any particular assignment (display class, part family or description) which is not called off.
This cannot be confirmed what is the real reason. I would recommend you to raise Service Request on this issue and then this would be picked up by analyst and will investigate in detail.
Regards,Sandip KarProduct Engineer - Bentley Systems
