I've been using V8i for a couple of years now, awhile back as per recommendation we switched to "Connect" edition Prosteel (i believe update 5), while its much faster (64-bit) and crash free unlike V8i it has that ribbon style task manager (which is doubling my search for any given command by 3x 4x) which is awful (little critique) ... anyways i've set it up as V8i to the best of my knowledge but still cant get around "clickin through" steel elements as well as 3D solids when i need to for example draw a concrete for context of the model. Any help would be appreciated.
I've made some screenshot if there's is any confusion about my request
1. V8i locating interiors with this options usually
2. Pic with inside connect edition ..not being able to find "hidden" point of the profile
Thank you in advance !
Mario
Hi Mario,Thank for posting your query over Bentley Community Forum.From the description, as far as I understood that you are looking snap/grab the point through the element for the element which is located behind it. Is this the concern which you are facing? If not, then can you please specifically elaborate?Waiting for your reply.Regards,Mihir Patil.
is
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Yes, this is the concern I am facing.
Thank you, but I already tried this with no help.
Can you elaborate how please?
