After installing version 10.05.02.50 of Prostructures, i got long names at some plates.
I checked options in a design file and Prosteel options. They are unchanged as before. Despite this i obtain the names of some plates with great accuracy, also at drawing partlist which is ridiculous.
I tried command „rebuild” without effect. Somehow Prosteel doesn’t take into account the length rounding tolerance which is set to 1.0 mm. Is it a bug in a new version ? Can I change this?
7713.Beam.dgn
Fortunately, new release of Prostructures 10.05.02.51 fixed this problem. Thank You
Answer Verified By: Grzegorz Zwoniarkiewicz
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
