How to model polyplate bottom face with 4 different elevation and top face at same elevation
Hi Shrinal,
Thanks for posting your query over the Bentley Communities Forum.
In response to your query, can you please help us with some picture or more information on the polyplate you require.
Regards, Alistair Lobo
Bottom face four points are at different elevation and top face four points at same elevation
The all 4 vertical faces should be vertical not inclined'
You can achieve that by first modelling a normal polyplate / plate and then using the Modify tool to apply a taper or any cut, as per your requirement.
Please let us know if this resolves your issue, or if you still require assistance.
