Hey hey,
Just playing around with the Auto Connections a bit, I've setup these before in Tekla, Advance Steel, etc but seem to be having some trouble in ProStructures/ProSteel.
I've been through the process of adding everything in the Preferences as required (plus other tabs) -
Setup a simple Column to Base Plate template in the Record Setup -
Choose the connection I have pre-made in the Baseplate Connection template -
As I'm using a 250UC as the example here I've only setup to that size.The 250UC column has the correct description to match the Preference Auto Connection naming -
So by choosing the Auto Connection button, selecting Base Plate and choosing the 250UC column by rights it should be picking this template -
I know its detecting the settings because if I delete the Auto Connection settings I just created it won't create the connection -
But the connection it creates is always this -
A Flat with Zero depth and always the exact size of the Column it's attaching too (in this case 254mm)When it should be creating the Base Plate from my Template file -
Not sure what I'm doing wrong here?
Cheers
Thanks for posting your query over the Bentley Communities Forum.
Please allow us sometime to check on this and we will revert shortly. If you require urgent assistance on this, we recommend you to please log a Service Request. to do so, you can refer the below Wiki -
Regards, Alistair Lobo
