Hello everyone
I want to model a bridge with a vertical radius of curvature of 1300m and a variable beam heightHow is it done with Prosteel?How is the bolt connection model for beams with variable height?
I will attach the file
Thank so much
Prosteel01.dwg
Hello Pham Quang Nang,
Thanks for reaching to us with this request. I can see, there are lot more things which we need to explain. So would you mind to create a Service Request so that we can better address this request. Also while logging the Service Request please attach all the needed documents with clear explanantion.
If you don't know how to log Service Request, you can refer the following link.
Looking forward to your update.
Regards,Sandip KarProduct Engineer - Bentley Systems
Can you give me any temporary solution?It would be great if I received a short video
I assume this will all be fabricated from plate so if you can model it the same way. The web forms the basis for the beam so if you accurately model that and approximate the flange curvature you will get a pretty good model
use insert plate by polyline or by points for the web. Insert arc plate for the flanges.
In case of using plate to model, the bolt connection model takes a long time to punch the bolt hole
thank so much
Please show me how to use this tool for steel plate editing
Thank you so much
