Is it possible to configure group details styles to dimension to "Holes or Front Edge"? There is a setting for "Holes or Outer Edges" - which is close to what I need, but it will dimension to both sides of a plate (which is not useful for us). Please see sketches below:
Holes or Outer Edges = dimensions to both sides of vertical plate (would prefer only front edge)
Front Edge = Correct for vertical plate, but would prefer holes in plan view plates
Thanks for any help
Hi lamensterms,
Thanks for posting your query over the Bentley Community Forum. We request you to please raise a service request for this issue so that we can better assist you over the remote session. Also, please attach your concern file.
Please follow the below wiki link to raise a new service request.
Kind Regards,Vyanktesh NamaSenior Technical Support Engineer Bentley SystemsBentley Structural YouTube ChannelBentley Technical Support
Hi Vyanktesh - thank you for the reply and the offer for remote session. I have had some help from Johannes on a related question, and he has given me a clue. I will do some more trials and let you know if I need additional support.
Thanks again
AutoCAD 2017 - N 402.0.0 SP1.2ProSteel S6 - 08.11.11.207Australian LocalisationWindows 10 64bit
