Within detail style config... how is "Part Type" classified? How can I assign a part type to any part? Is it the part description or other category?
Thanks for any help
What you did in your dimension rule was to say: The element to be dimensioned is either a purlin plate (done by the purlin connection) or any shape with the description "Purlin xxxx" or any plate with the description "Purlin xxxx". Shapes are no anymore on the assigned part list as they have already a filter value. the same for plates.
For descriptions in general see:
The use of the Part Description File (FDT) in Detail Center. Product(s): ProSteel Version(s): CONNECT Edition (10.XX.00.XX) Area: 2D Display - Detail Style Subarea: Line Display Original Author: Detlef Hackbarth… Last edited over 1 year ago in ProStructures > ProStructures Wiki
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Answer Verified By: lamensterms
Hi, is it possible to change part type from end plate to polyplate or all connection plates to polyplates?
