In my 3dmodel I have quite big area covered by plates. There are many holes 5.6 mm for bolts drilled in plates. I do not want to insert bolts in all these places, I simply need to calculate total amount of drilled holes to calculate bolts for them.
Is there a way to find out this amount of these holes?
The best, if I can calculate this depending on the diameter of holes.
Yes, in the Partlist you can add a column for hole numbers in parts. If you are familiar with List and Label you can sort by Diameter,
The field to add is NumHoles
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
I know that way, however I'm not familiar with List and Labels matters. I rather looking for any simpler solution.
ProStructures 1.0.0.8 from Nov 7 2019
Hi with the ProSteel Tools you can find Elements per Hole diameter.
Then you create a Partlist per Diameter and Export it to Excel.
Or make a drawing Partlist and add the column Boltcount.
Yes I know that tool, an I use it in the the way you described, but i look for any faster and shorter way.I was hoped that ProsteelToll during replacing type of holes, or changing their diameter- is counting them, has the result and it is possible to see that figure, but as I see it is rather not possible.Anyhow thank you for your help.
Ok, great to hear, there is no other way yet, or you need to learn .Net coding :-)
