Hello
How we can change width factor in Position Flag in MS Connect edition? Every time the values back to original position. Then, the position number is too wide.
Hi Grzegorz, did you change the width in the text style itself ? This should work.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Nop, it doesn't work. Every time the fonts back to original width.
Guys.
YOu are the support from Bentley side. Give me the solution.
How I can change text style "itself"???
Hi Grzegorz,
We really apologize for the delay in our response to your question. In order to get the quick assistance for your queries, we request you to please log the service request, for that please refer the below wiki link-
In response to this query, first of all, create your required text style in the Text Style dialog then apply your newly created text style to the Position Flag style, please refer to the below image. In the Position Flag Definition dialog, you can set your required settings for Text type, Text Style and Text Size etc.
Please let us know if you need any further help on this. Thank you!
Kind Regards,Vyanktesh NamaSenior Technical Support Engineer Bentley SystemsBentley Structural YouTube ChannelBentley Technical Support
