Hey again,
We've just figured out the hard way that the latest version of ProSteel Update 6 does not work with previous versions of ProSteel (Update 5 has been tested to not work).A model was completed from start to finish using ProStructures Update 6, a user has tried to open this model using Update 5 it crashes every time (we have tried two different Update 5 versions)Update 5 can Reference in the model, but it loses its ProStructures elements and everything turns to Solids (even copying / pasting the elements they are still just Solids instead of ProStructure elements)
Can we please get this tested.
Thanks for posting your query over the Bentley Communities Forum.
We believe you have also raised a Service Request for this issue and all further communication will be carried over that request.
Regards,Alistair Lobo
Thanks Alistair.Speaking with Support, conclusion is Update 6 is not backwards compatible.The List of Changes website has now been updated notifying this
It is updated now, thank you for making us aware of this.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
