Hi, I'm finding it difficult to get the dimension text to the correct scale. position balloons, material list etc are all at correct scale but dimensions are 10x the scale. i am sure i have looked at every setting. Any help would be great !thanks
Hi Beau,
Thanks for posting your query over the Bentley Communities Forum.
Could you please attach your concern dgn file for our investigation? Also, if you require more prompt assistance on this, we recommend you to please log a Service Request for the same. You can follow the below Wiki for guidance on how to log a New Service Request -
Kind Regards,Vyanktesh NamaSenior Technical Support Engineer Bentley SystemsBentley Structural YouTube ChannelBentley Technical Support
Thanks for logging service request SR#7001395004. This dimension issue you have observed in the 2D drawing created via Detail Center. So, to adjust the text size or to change other parameters you need to check which dimension style you have used in your Detail Style > Dimensioning settings.Please follow the steps below for a better understanding.1. Open Dimension Style dialog and create a new dimension style or modify the existing one as per your requirement and save it.
2. Preview you drawing from Detail Center and open associated detail style dialog. Go to Dimensioning > Common and here set your dimension style.
3. Now, update the preview and you will notice the changes.It's glad that we have resolved your issue over the service request communication.
