Please help.
I have installed Prostructure Release 6, I have reinstalled did not fix issue.
Trying to access Properties (through File menu and right click) but Properties dialog box doesn't appear.
When I hover cursor on properties tab above picture. Properties Doesn't appear nor allow me to unpin.
Please advice.
Thank you
Kind regards
Dino
Hello Dino Crisostomo,
Thanks for posting this query in Bentley Community Forum.
May I know, are you using in multiple screen. This may happen when user use multiple monitors and the dialog box once opened in other screen, get stuck in that one.
So to make this avoid, following steps you need to do.
1. Delete all the *wndcfg.sve files from the User>AppData location (C:\Users\<user name>\AppData\Local\Bentley\ProStructures\10.0.0\prefs\Personal_WndCfg). Attached the Wiki link to show how to do.
2. If the above step does not resolve your issue, you can do restore defaults. For detail how to do the Restore defauls please follow the Wiki Link below.
How to restore the default factory setting for ProStructures CONNECT Edition? Product(s): ProStructures Version(s): CONNECT Edition (10.XX.00.XX) Environment: N/A Area: N/A Subarea: N/A Original Author: Vyanktesh Nama… Last edited over 2 years ago in ProStructures > ProStructures Wiki
Dialog Boxes Off Screen Product(s): ProStructures Version(s): V8i, CONNECT Edition Area: N/A Subarea: N/A Original Author: Johannes Michalowsky , Bentley Product Advantage Group… Last edited over 2 years ago in ProStructures > ProStructures Wiki
Hope these will resolve your issue. If not then do let us know.
Regards,Sandip KarProduct Engineer - Bentley Systems
Answer Verified By: Dino Crisostomo
Thanks Sandip
Step 1. Didn't work, but Step 2 resolve the issue and properties dialog box appears now.
