6712.test.dgn
I am having an issue with the bent shape exported into IFC. Using the BIMvision for viewing IFC, the exported bend shape is not showing. This was not an issue with CE Prostructures version 5.
Can someone please check and see if this is a common issue and how to fix it.I have attached the test model for review. Another example is continuous handrail end closure bends and horizontal bends.
I am using Prostructures CE update 6. Version 10.06.00.60
LM
Hello LeoM,
Thanks for reaching to us via Bentley Communities.
Can you please help us to understand, is it Metric or Imperial model?
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi LeoM,
I have investigated and found the issue. Let use also check in previous updates and also let me investigate. Will get back to you shortly.
This is confirmed that is a Bug. We request you, if possible do raise a Service Request and we will prioritize the issue.
Hi Sandip,
Thanks. I will do that.
Leo
Thanks for raising the service request (SR#7001415295) as requested.
We would like to inform you that this issue resulted in Bug Report 887843, and will be evaluated by the product management team for our regular CONNECT Edition updates.
Kind Regards,Vyanktesh NamaSenior Technical Support Engineer Bentley SystemsBentley Structural YouTube ChannelBentley Technical Support
