Hi, I tried importing a .dwg file created in prosteel (they didn't say which version). The file imports, but doesn't have any shapes.
I looked at
https://communities.bentley.com/products/prostructures/w/structural_drafting_and_detailing__wiki/37094/how-to-migrate-prostructure-v8i-older-select-series-to-prostructures-connect-for-autocad
and
https://communities.bentley.com/products/prostructures/f/prosteel-forum/225422/import-prosteel-for-autocad-in-prosteel-connect-edition
It says there should be a key-in for the ProStructures Migration Assistant that you start with "prostructure migrate", but typing that doesn't work.
Do I need to download some program for this to work or?
Thanks in advance
There is no migration into CE, it should directly open without problems and convert all elements.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Answer Verified By: Jaka Dimnik
So it must be something with the file I assume?. Would you mind opening it and see if yours also doesn't show? Left picture is dwg exported to solids, right one is the original .dwg i tried to open
2260.test.dwg
