Is it possible to add a new property to PS shapes? For example if we wanted a note 3 and note 4?
you can use Item types to add extra data
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Hi Michael,
Thanks for posting this query in Bentley Community Forum.
Yes, you can do add other properties using EED under Data Tab and the same is available in Group Data Tab
The levels you can change in the EED file by opening in Notepad.
In another way you can also use Item Types to get additional properties how many you want.
Please refer the following Wiki articles to know more about this.
Regards,Sandip KarProduct Engineer - Bentley Systems
