I'm using Prostructures Connect Edition 10.05.01.11
I've placed a plate using the Steel placement tools.
I need to edit length. OI open the Plate properties and the length fields are greyed out. Why?
The only field that is editable is the thickness.
I need to edit length, i should not have to place new plate.
Best use the grips, tick on the plate, blue grips will appear, strech it by those.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Answer Verified By: Nicole Joyal
Aha, thanks Johannes. This worked perfectly.
I thought i was supposed to use PS property tool box to edit.
Nicole Joyal
Bridges & Highway Structures
Manitoba Infrastructure
Canada
