[question] 2d drawing "move" only moves part of the object
Hi, what is the correct way to set up the detail style, so that after 2d drawings are inserted, you are able to move parts around freely? Currently, only the main group part moves, the other (sub) elements are impossible to move. I'd like to keep the 2d drawing with element info, not transform it into only 2d lines with detail style (if this is possible?).
I hope you can understand the question (see picture).
If I enable "Select group as whole" I can move the group around, but this has another problem of selecting the whole group, and I'd like to move only individual parts (for example in picture I'd like to create more space between side and front views after already inserting 2D.
I can get around that by manually exploding elements, but then I'm left with a bunch of lines.
Additionally, is there a way to keep element info when detailing groups with group detail style (dialog: detail center -> groups)?
At the moment the only info that is kept is the main element of the group, other (sub) elements info are not showing when attaching a position flag to them. (picture)
For some objects, I would prefer to put the position flags myself, so I'd like to know if there is a way to be able to do this.
Looking forward to your reply.
Best regards
