Are these the correct design file settings? I work with OBD also and these settings are sometimes different?
Hi Richard,Thank you for posting your query over the Bentley Community Forum.Yes, these are correct settings but, it in the default settings the resolution is 10 per distance millimeter.Otherwise everything looks fine for me.Regards,Mihir Patil.
