How i can update group weight to several groups at the same time?
Hi Dmitriy,
Thank you for your posting over Bentley Community Forum.
Can you please elaborate your concern? Normally, group weights are getting updated automatically. Maybe some of your structural objects are getting zero-value weight. Kindly double check the structural objects if material property is present. You may check this from the Structural Properties of the object (Partlist Data > Data).
Thanks & best regards,Kemuel JancordaTechnical Support EngineerBentley SystemsBentley Structural YouTube ChannelBentley Technical Support
