This is the old welding symbol tools for V8
Hi Nguyen,Thanks for posting your query over the Bentley Communities Forum.
In response to this, could you please elaborate your concern?
Kind Regards,Vyanktesh NamaSenior Technical Support Engineer Bentley SystemsBentley Structural YouTube ChannelBentley Technical Support
I trying to load the application *.ma that i use in V8 XM using MDL applications, but only got failure message.
Pls show me how to do it !This *.ma was not able to use in V8i, only V8XM
We have to investigate internal, if somebody has the original code.
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
We still include it with OBD as does OPM:
But when trying to load the OBD .ma into PS U7 it fails, so there’s are dependency's
in ProStructures there is also a weld symbol command with a lot of finctionality
Do i have to pay for extra lisence for ProStructures ?
If you do not have it, only OBD, yes. You can load the weld makro under OBD it will work.
