Hi guys. Is there any documentation on discussing PS_REBUILD options? Some items there are unclear on what it actually do.
Any help will be deeply appreciated. Thanks!
Actually there are some options in the command require some caution, therefore it was not made public.
In the MicroStation version it is the key-in ProStructures rebuild, with identical options.
The basic useful ones are explained here.
60 to recover and rebuild the elements in the model.
50 to clean up the model.
41 for updating Graphics and non-reacting elements
8 would show you potential problematic parts
7 is useful when by any reason a part has a length of 0, this could cause crashes in detailing
6 removes faulty parts
1 is useful to identify parts causing long modeling times
12 is also a test for potential problematic parts
14, 15 to select only curved and bend parts
42 if you changed your tooltips.ini and won't restart your application.
20 don´t use as it could cause blocked drawings, it could be used for example to delete all Position flag or bolt styles in the drawing
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Answer Verified By: Justine Bautista
Thanks Johannes Michalowsky this is very informative.Hope Prosteel will soon complete the list too!
