Can someone describe the purpose of this command, I cant find it in the help files:
Hi Steve,
Thank you for raising your concern over the Bentley Communities Forum.
The Pick Parts to connect option from Detail Center allows the user to copy and apply the Detail Styles of the selected to a single part or loose element. This is convenient for users who have newly introduced parts and wanted to apply the similar detail style without the hassle of checking a long list of detail styles.A short video is provided for better clarity of the Detail Center feature.
If you have further clarifications or any other concerns to discuss, I would suggest you to log a Service Request so we can have a live session. How to Log or Report Service Case for ProStructures? Product(s): ProStructures Version(s): CONNECT Edition Area: N/A Subarea: Alistair Lobo, Bentley Global Technical Support Updated By: Vyanktesh Nama, Bentley Global Technical… Last edited 9 months ago in ProStructures > ProStructures Wiki
Thanks & best regards,Kemuel JancordaTechnical Support EngineerBentley SystemsBentley Structural YouTube ChannelBentley Technical Support
Answer Verified By: Steve Hipp
Its the same function as connect to detail style if you have set a detail style to being default, just that you need to pick the part.
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Thank you, that gif explains it perfectly. I am between contracts & was exploring some of the commands that i have never used before to see if any would be useful to my workflow. I could not find a description of this command in the help files. There are alot of these commands I cant find any documentation for so I ask here for help with them.
