Will there be an update for the ProSteel Tools for CONNECT Edition Update 7.0? The latest that seems to be available is for ProSteel CONNECT Edition Update 6.0.
(48) ProSteel Tools - ProSteel CONNECT Edition - ProStructures Wiki - ProStructures - Bentley Communities
Here you find the tools for Update 7
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
I had the tool set loaded & it opened fine, but when I tried to use them all the PS icons got wiped out. relaunching PS does not restore them to their default icon display. See screen shot.
OUCH! Beta testing?
I will hold off for the time being then,
but eager and curious to check them out,
once the ALL CLEAR is given.
Johannes will likely pipe up, as is
his Wizardly wont,
and pull a virtual rabbit out of his hat
to save the day.
please do a repair with installation, currently cant replicate
Answer Verified By: Steve Hipp
This solved my issue, my icons are back
Thank you
Happy to hear. :-)
Answer Verified By: BFG
