How do I adjust/remove the layers that are automatically loaded into ProStructures apon opening a drawing?
Hi MINI696,
It actually depends on what you are trying to do.
The default settings of ProStructures is to make use of the Configuration/Layer under the ProSteel options. (See screenshot below)
Notice that whatever is listed under the ProSteel options is also available in the AutoCAD layer. If you changed a layer you would also need to change it or assign it in the ProSteel Options > Configuration /Isometric > Layer
If you want to customise your own layer and be more specific I would suggest you read the link shown below.
http://communities.bentley.com/products/structural/drafting___detailing/w/structural_drafting_and_detailing__wiki/1816.aspx
Answer Verified By: Michael Kornbrekke
Is there a way to stop ProStructures inserting any layers automatically?
I have answered this on the other post.
Where???
