After Creating the group when i tried to change the properties of the one of the member by selecting, it select the whole group rather than a single part.
Any idea how to fix this issue?
please advise me as soon as you can.
harry
Check the global ProSteel options -> Options field there is option 'Select Group as whole'.
does it also work for the 2d drawing?
i mean after creating 2d drawing, if i want to delete some dimensions manually, i can t select those individual dimensions, as when i tried to select the whole drawing select in white border!
Dear Sir,
In 2D that's CTRL + H or Pickstyle 0. PickStyle 1 is Grouping on.
Its a Selectable Switch for Grouping.
Bentley Structural YouTube Channel
Johannes MichalowskyProduct Engineer
Answer Verified By: Hardik Jariwala
Kool Thanks It has worked.
