When i tried to add weld flag to shop drawing it does add them but the distance (arrow line) is varied as some of them too long which make weldfleg far from the drawing and some of them too close which make drawing so busy.
is there any way to control those lines?
same with dimensions line distance too?
Please help me out.
The distribution of the weld flags are controlled within the Detail Style used.
Please see attached screenshots for your reference.
About the distance of the lines of the Dimensions you can control it from the Detail Style too. Change the values and see the effect on the preview of the 2D drawing.
Hi Thanks for your reply and clarification but I am still not able to detail a small frame and I want to show
1. plan elevation section and iso metric view.
2. I want each object posion no and as well as welding flags where I put weld in the model.
after try try and not successful by doing that I am finally attaching my file for your review.ismail2.dgn
Answer Verified By: Jitendra
Please add weld symbols/flags in to group.
