Where can I find these? It seems there is an access restriction to the Software fulfillment center. (I can't download anything)
Thanks in advance
The Enablers are not released yet. at least I know there is already a ProStructures Beta one.
If you set Navisworks to use AutoCAD 2014 output and had a previous one installed, it should work though.
http://communities.bentley.com/products/plant/design___engineering/f/5927/p/120615/372527#372527
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
additionally you can use NWCOUT command than you don´t need an enabler.
If you can not execute NWCOUT see:
