I have some rebar elements that are attached to MicroStation Solids. I have converted the solids to Concrete Solid elements. Now I have MicroStation solids with rebar and ProConcrete 3D elements with no rebar assigned. Can I reassign the rebar to the ProConcrete 3D element rather than the MicroStation Solids?
Or can I copy rebar from one 3D element to another?
Thanks for any help.
there is an option to clone rebar, that will clone complete sets of rebar
or you can save your settings as a template and reuse it on the ProConcrete element
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
