Dear all,
Is there any option or any tool to take over a part family and position number already in some other parts(i.e. from Old parts) to be transferred for the new parts.
Thanks for your help in advance.
Hi Prabhakaran,
Thanks for posting your query in Bentley community Forum.
As we understood from your query, that you want to assign old unused part Position no to the new part.
Please correct us if we are wrong.
If so then follow the below steps:
1. Go to Options window in Positioning Dialog and check on the Save single part pos numbers. Activating this, you will now see the old position no. in the Element Property.
2. By default the Pos. No box is restricted to edit. To remove restriction, go to ProSteel option > Logilink and unlock the editing of part properties.
See below image
3. Now you can change or assign the position no in the element property.
4. It is recommended, after changing, check on this Lock editing part properties to avoid any manual mishandling.
We have also attached one short video to clarify this issue.
2018-01-25_20-18-16.zip
We hope this will answer you sufficiently.
We are looking forward to hear your update.
Regards,Sandip Kar
Regards,Sandip KarProduct Engineer - Bentley Systems
Answer Verified By: Prabhakaran.P
Have your issue been resolved?
We will be very happy if you update us about this.
Sandip Kar
Dear Sandip,
thanks for your valuable answers, Its working for me.
I have also another question in it.
It is Possible to carry over the original position number to the position number.
Best Regards,
P.Prabhakaran
We really appreciate the time you took to verify our answer. Thanks for your cooperation and patience.Can your explain your second requirement in detail so that we can provide you with better solution.
Some example with images will be appreciated to let us know your requirement.
Looking forward to your response.
In this above image,
In Original pos.no Will be filled {CP5.4.1.2-B-}695.
In Pos.No it is Empty as of now.
But what I need is I just want to take over the Original pos.no to the Pos.No .
It is possible to do by using any other tools in prostructures.
