Hi Guys,
I have produced fitting sheets via the Detail Center Express. I tried to change of the fitting/cleat in the model and also copied it and grouped that fitting/clat to another member. It is now red in DC list and 2 of them are listed, one is red and the other (which must the copy) has no color. Then tried to update the red one using the "Update Changed 2D Drawing". The fitting detail itself got updated but the containment list did not. Is there a way for the containment list to be update as well automatically? Thanks in advance.
Hi Brian,
After copying your fitting, you need to do positioning and then go to Detail Center and update it. After updating you will see one part must be in red and the copied one also to be included in that one, if there is no change you did after copying. And then I believe it should come in Containment list in drawing.
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip,
Can you please clarify further? which one do we update? the red one or the copied one? we did the red one as originally stated but it did not work for the containment list. we also already tried to update the copied one but the "Update Changed 2D Drawing" and "Update 2D Drawing" is disabled. The only way we can get the containment list updated is by doing a reblock. update does not work. This was the case on ProStructures w/ Microstation v8i SS8 and now also in ProStructures w/ Microstation Connect Edition and even in Update 2.
How are we going with this? Can we please get answer to this? Thanks
