Detail points are not showing up in detailcentre. I have numbered all the connections using positining, and enabled 'scan joints' in the DC settings but joints do not appear.
Hi cadaver,Thanks for posting your query over the Bentley Community Forum.In response to your requirement, please find the solution as described in the Wiki link below -
likely Naming is is not set in the link options in the ProStructures Options. also you need the extended link options.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Thanks Johannes,
see below for current settings
In Label there needs to be an information, that the joint shows up in Detailcenter. It can´t be empty.
OK. I think i see what is happening, it will list un-named joints that have part numbers, but looks like it will only show joints between members, not things like stiffeners, even though stiffeners can be numbered and labelled.
So, this raises another question, if I manually model a joint using polyplates, how do I set it up so it can be detailed as a joint? Do I need to add a manual logical link?
