The British Standard library on ProSteel seems to be missing a few shapes which I need, specifically a 660x20 CHS.
What is the best way of accessing a more comprehensive library and how do I load that in to ProStrucutres?
Thanks in advance for any help.
Lee
Actually you can just change the key value for simple shapes like flats etc. not being in the Database.
eventually you need to change the naming convention
The part list data will be created out of this values
all shapes are in editable MDB´s, you can add your own ones and copy from other databases.
https://communities.bentley.com/products/prostructures/f/prostructures-forum/97706/adding-a-shape-to-shape-databaseadding a shape to shape database
In the SPC database you find several other diameters.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Hi Lee Sharratt,
You can also refer the following Wiki link to know how to add new shape to mdb file.
add new steel sizes to the shapes database file
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip,
I'm running ProStructures V8i S8. I've just tried searching the folder I have for 'Britain' and nothing is showing up.
Many thanks
Hi Lee,
Can we have your direst contact detail so that we can call you and do live session to explain this?
Also please mention your ProStructures Version.
Regards,Sandip Kar
Hi Sandip - I've just sent you a direct email with my contact details.
It was a nice meeting over the call and it is clearly explained over the call, where that Britain.md file located. For your referenece I am sharing again the path where you can find the file
Shape mdb file location : C:\ProgramData\Bentley\ProStructures V8i S8\WorkSpace\ProStructures\Data\ShapesAnd in that you will find Britain and BritainNew mdb file where you can add new sections as your need.
I hope this is now clear to you and you are now got this.
Thank you for your cooperation and patience.
Hi Sandip, it was nice chatting to you and Johannes earlier, I found it really useful.
Thanks again for your help.
