Dear all,
Is it possible to draw a chain in prosteel.
Please refer the below picture
Kindly give your advice.
Regards,Sandip KarProduct Engineer - Bentley Systems
You could look at microstation 3d linestyles to model the chain.
Hi Prabhakaran,
In that case you can create block in Microstation and then can call that block in ProStructures.
Thank you for your Solution
Best Regards,
P.Prabhakaran
Dear Sandip,
I will work it as you said.
