Dimension chains in 2D drawings
this is probably an enhancement request.
the dimension objects in the 2D shop drawings are output as individual dimensions as below left. This makes modifying dimension chains difficult. Ideally dimension chains would be proper fence dimensions as on the right. Which makes inserting and removing vertices, or moving the dimension line easier
