The section "Labels" are showing in my model and in my drawings.
How do I turn them off?
They are grayed out in the Shape Label dialog box and the Part Label dialog box.
Is there a global setting I am missing?
Hi Andrew,
Thanks for posting tjis issue in Bentley Communities Forum.
To make work with Label, first you need to disable "Use template data" option and then disable label.
Regards,Sandip KarProduct Engineer - Bentley Systems
Answer Verified By: Andrew Cairns
