Hello
When I want create the group, Ps give me the info "Select main part of group:* WARNING UNIT NAMED 5723D ALREADY EXISTS - INPUT REJECTED.Select part of a group:Cant retrieve Group from selected Part" Version 08.11.11.207 Acad 2016 Win 10
Normal beam and plate.
What is it?
Please use the verify Group command, it will detect any inconsistency in grouping
For AutoCAD you will see results in the command line after execution..
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
