Hi Alistair Lobo or anyone,
Can you please help us tweak our ProStructures Connect Edition so the NC1 data file created is exactly the same output as the attached - detail sheet with the sample NC1 data file. Hope we can get an answer as soon as possible. thanks.
Note : the out of the box settings does not work for this particular fabricator and they are saying they are using a DAITO machine.
C8014.zip
Hello Brian,
Thanks for posting your query over the Bentley Communities Forum.I will have a look at the attached file and get back to you with a solution soon.Regards,Alistair Lobo
Hi Brian,
Can you please explain more in detail on this what actually you are getting issue? Is there issue in accuracy of output or something issue in header line which which is not detected by the machine. The NC file you shared looks quite identical like our's output. So please point the area which is not getting read by machine.
Looking forward to your update.
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip,
the sample file we've sent was from the fabricator, our question is what are the settings we need to get that same NC1 data file. can you please send some screenshots of your settings for us to get that same output file. thanks
We are also getting identical output. Only header, I can see is extra from your's one which you can customize or can allow system not to write and those are coming from Header -ST Tab
And the output will be like as below
Also attached one sample NC1 file for your reference.
https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/275893/C8014.NC1
