We have recently updated to AutoCad2017 and needed to update Object Enablers for AutoPLANT and Prostructures to continue using legacy drawings.
AutoPlant installed okay however Prostuctures will not install and states that AutoCad 2016-2017 is not installed.(see attachment)
Any suggestions would be appreciated.
Russell
Hello Mr. Pertot,
This normally hints that a Registry entry for AutoCAD 2017 can´t be found.
please install the OE with the same user as the installation was done or
When the Admin installed AC 2017 it needs to be that AC 2017 is started under Admin at least one time before switching to another user.
This should make the copy of all Registry entries to other users possible.
In last resort, a reinstall of AC 2017 under the specific user is recommended.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Hello Johannes,
Thanks for you prompt reply. I have finally gotten back to this and your suggestion has worked perfectly.
Thanks again
