Hi Guys,
Is there a way we can unfold the conical funnel/plate? We find that ProSteel can create conical funnel using the insert arc plate but we can't find how to unfold it? Is there something in ProSteel that can do this so we don't have to dqaw this manually? Please advise.
Hi Brian,
Thanks for posting this query in Bentley Community Forum.As far as my knowledge this should go for Enhancement. However I will investigate on this and get back to you shortly.
Regards,Sandip Kar
Regards,Sandip KarProduct Engineer - Bentley Systems
We have the Unfolding option in detail Style, but that works for curved plate created via Straight plate. Due to dimension critical, unfolding for plates in conical shape created by Arc plate is not available.You need to do unfolding manually for that curved plate.
Thanks Sandip,
