Hello
We have problem with the weight of the bent plates. Model don't have any issues but some plates have wrong weight. See the position 17523. This is 2mm bent plates. However, when I change thikness of the plate on for example 3mm , everything looks good. Can you tell me what going on?
Hello Grzegorz Bem, Thanks for posting your query over the Bentley Community Forum.We have tested your case and were not able to reproduce this issue. Can you please attach your model so that we can replicate this issue and provide a solution for the same. Looking forward to your update. Regards, Alistair Lobo
Hi Grzegorz, This issue that you are facing is generally very rare and does not happen normally. To get the correct weight for the bent plates you have modelled, we suggest you to switch on the Modeller & Solid kernel in the General Data > Layout while in the PS Properties of that shape.Also, it is better to create user parts for such shapes and then use the same in your model.Regards,Alistair Lobo
