Hello
I have a problem with Prostructure stiffener Connection
How to unlock dim. 4 and 5 ? I would like to change that, but I can only edit spacing of bolts (dim 6)
On our side its working. (CE Edition 10.00.03.58)
We would need your Model and the version number of ProStructures you are using.
Many Thanks !
Best Regards
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
I'm using V8i 08.11.14.238
Adam Mastalerz
True, the option is not working in V8i. Prostructure ONNECT Editon Update 3 is available.
For Enhancements and fixes see
Answer Verified By: Adam Mastalerz
Hi Adam,
It will work. You need to enable From Edge in Dimensions Tab as shown in the below image
And this is also same in CONNECT.
Regards,Sandip KarProduct Engineer - Bentley Systems
Many thanks for clarification :-)
