Hello
I have issue in endplate connection in ProStructures CONNECT update 3.
When I make endplate connection (splice/normal/flange) plates do not show. Only a line. When I switch off "as polyplate" it show flatsteel correctly.
Enyone know how to fix this ?
Hello Adam,Thanks for posting your query in the Bentley Communities Forum.In response to your issue, we suggest you to fill in a suitable value in the length field and then you should be able to view the Endplate correctly.Regards,Alistair Lobo
Hi Adam,On further investigation it was found that this is a known defect. Hence, I will log a Service Request for the same on your behalf and will take this issue on priority.All further communication will be carried out on the Service Request.Regards,Alistair Lobo
