Connect update 3 I models
Do I models work with full ps properties in the latest update 3?
The release notes say update 3 is compatible with I model 1.6 format but when I publish it gives me an option to use 2.0.
should I use 1.6 or the more current 2.0 what’s the difference?
It does not matter what I model format I use I still do not see any properties in the I.dgn or the connect I model.
How do I see ps properties when I open or reference the prostructures dgn file or a I.dgn file.
Bentley view is really annoying in you can’t change any configuration not even the ms schematic path it also refuses to honour
any project wise managed workspaces.
