I am attempting to use sub groups to assist with automatic detailing.I don't want sub group drawings or sub group numbers at all, only the additional dimension settings that the sub group allows.Please see below screengrabs for current result as well as screengrab of current sub-group/group settings to achieve this result;
The automatic detailing result is pretty much perfect for what I want to do.However, position numbering is completly f*@ked.
I don't want any sub group numbers, and I don't want phantom entries in my group containment lists if the sub group has not been numbered.Is there a better way to achieve the same detailing results? Or are there tricks that I don't know about regarding position numbers when sub groups are involved?
Hello Andrew,Thanks for posting your query over the Bentley Communities Forum.In response to your issue, I would like to know that, you just need the sub-groups for better control of displaying the dimensions when generating 2D drawings, is that right ?Regards, Alistair Lobo
Thanks Alistair,Yes, correct.I am using the sub group to create the dimensions for the stair tread connection plates.
Hello Andrew, We are sorry for a delayed response. Addressing your issue, if you don't want any Sub-Group Position Number & also do not want the same in yourcontainment list, please switch off the check mark on 'In partlist' and switch on the check mark for 'Don't Position' in the PS Properties of the parts of the Sub Groups. Then you can carry on the process for generating your 2D drawings via the 2D detail Center. We believe this should resolve your issue. Please update us on the same so that we can assist you further if needed.Regards, Alistair Lobo
