I noticed that "Object view at point" is not working correctly.
If I point a certain fragment on the shape, the command should allow me to choose a view exactly at this point. However in my case it always creates view in the center of the shape:
Hello Tomasz Surmacz,
Thanks for posting this query in Bentley Community Forum.
It should not be happen like that. Can you please tell us which version of ProSteel you are using?
We need to do one online session on this. Please do provide us with your contact detail so that we can reach you and can resolve the issue.
Regards,Sandip Kar
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip,
Version 08.11.11.207 from July 11 2018 for Autocad 2016 SP1.
Several computers in our office running this configuration ( 08.11.11.207 + Autocad 2016) suffer this problem.
What contact details do you need for online session?
with your Version 8.11.11.207, we can not replicate, if you set the view depth to 50 and go to upper flange in this example, no hole is visible when you go to lower flange only lower flange and the hole is visible. Therefore we need an online session.
Bentley YouTube Channel
Johannes MichalowskyProduct Engineer
If I understood your answer correctly, the problem is not with view depth and what's visible and what's not. The problem is with view selector (coloured arrows) that ALWAYS appear in the center of element, regardless of the point I choose. See the last picture in my original post - I'm pointing the end of the element (by the green hanger) and view selector shows in the center of element.
We can do online session by Teambeam. What time and date?
