The Connection Center has no own help segment. However the Connections available in the center have their own Help files inDrive:\Program Files\Bentley\ProStructures CONNECT for AutoCAD\AutoCAD 2019\Prg\Plugins and will open per connection
In Drive:\Program Files\Bentley\ProStructures CONNECT for AutoCAD\AutoCAD 2019\Samples\COM Macros you will find Examples prepared for testing the functionality by yourself
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Hi Johannes,
Thank you very much.
My company's ProSteel version is 'ProSteel for AutoCAD 2016'. As per your information, I found the related folders (...\Program Files\Bentley\ProStructures Ss6R1\AutoCAD 2106\Prg) but there are no Help files. And there are some Examples in another folder (…\Program Files\Bentley\ProStructures Ss6R1\AutoCAD 2016\Samples\COM Macros).
Is it possible for you to send those files to me when you have time? Or where will I may get them (website)?
Thanks lots.
William
The Help files (*.chm) are in the subfolder Plugins. One can open them with the standard help or by doubleclick.
Thanks Johannes. I found them.
