I am putting out my first set of deatils/drawing and I am having a hard time with the following issues:
-What is the reasoning the Isometric view is not properly aligned directly below the Front View, especially being the layout of my Detail does not properly align? I have selected 'Bottom' for Detail Style/Position Iso in the Design editor… but it keeps throwing the Iso to the right.
-Why is the qty in the drawing different from the quantity in the Parts-list? (FYI… the drawing is the accurate count)
-I have struggled, endlessly with trying to clean up the dimension texts so they do not overlap and blur. Any guidance of how I can do so without manually editing each drawing?
Thanks!
B
Dear,
Please attach snap for better understanding.
shrinivas jadhav
can you give me your email id so i will give you some documents for your ref.
shrinivas
sure… please email me at bmalaky@hotmail.com.
Can you please explain what a 'snap' is? I am relatively new to the terms.
Unknown said: -What is the reasoning the Isometric view is not properly aligned directly below the Front View, especially being the layout of my Detail does not properly align? I have selected 'Bottom' for Detail Style/Position Iso in the Design editor… but it keeps throwing the Iso to the right.
What about if you select other Isometric views (Isometric 3 or Isometric 4) in Detail Style:
Unknown said: -Why is the qty in the drawing different from the quantity in the Parts-list? (FYI… the drawing is the accurate count)
I guess you inserted Drawing partlist that list only parts those are in particular 2D Drawing. That's why you are seeing qty as 1.
Thank you Darius!
Switching the Iso view to 3 or 4 did the trick… thank you very much!
As to the part list discrepancy… is there a way to have the drawing part list reflect the total qty of the parts?
Also, any other recommendation on cleaning up the dimensions from overlapping?
Bernie
