Hi
I am using ProStructures Connect version 10.7.0.40. I want to add the bending schedule of only certain parts of the structure to the bending schedule and then place a live table on the drawing sheet. I see this is possible with ProSteel with the Drawing Partlist, but there is no option like this for ProConcrete
Marika Knoetze
This is ultimately what I want to create:
Marika
Hi Marika Knoetze,
Thanks for posting your query in Bentley Community Forum.
We are working on your request. We will let you know for any possibility for this.
Sandip Kar
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip
Were you able to find a "live" table that I can place on the sheet that shows the bending schedule?
Kind regards
Hi Marika,
We are extremely sorry for our late response. I have created one Service request on this ( I believe you got the mail ) and have reported an Enhancement # 1006467 on this Request. We have already discussed internally to work on this. May be in future update this will be implemented.
Thank you.
Regards,Sandip Kar
We have worked on this and found one workaround to place the partlist in drawing itself.
1. Create Bar bending Schedules for your selected area which you are going to show in your sheet
2. Export this bar Bending Schedule in Excel format.
3. Switch to Sheet
4. Run Place Table command (MS)
5. Select 3rd Icon , Excel file
6. Find Exported file by browsing.
7. Place it on the sheet.
Attached a video lin which explain clearly how to achieve that.I hope this will resolve your issue atleast in great extent.
