I am attempting to model an elliptical 3d solid.
I have tried creating a plate using a created 2d ellipse as a template (polygon, circle or arc) -----This failed, and produced only a circle!!!
I have tried creating a 'User Shape' using a created 2d ellipse as a template) -----This failed, and produced only a circular solid when modelled!!!
Has anyone any idea for a solution to this problem?
Kind regards,
Ged Etherington
Hi Ged,
We have already replied this issue through Service request you raised through SR:7000799794
and we provided a Workaround for that. this has resolved your issue.
So please update on this.
Regards,Sandip Kar
Regards,Sandip KarProduct Engineer - Bentley Systems
I have the same issue - what is solution for that ?
Adam Mastalerz
Hi Adam,
I only received a 'workaround' after I raised a 'Service Request' but it works ok for my purposes.
I have attached a screen shot for you to utilise.
I hope this helps.
Ged
Answer Verified By: Adam Mastalerz
Hello Adam,Just as Ged has suggested, that is the way to achieve Elliptical Steel Plates in ProSteel.You can also refer the below Wiki and check the video along with it. Regards, Alistair Lobo
